http://cgi.ebay.com/ebaymotors/04-0...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
$79.99 for K&N CAI , grab a new filter and it's a cheap deal!
try replacing that rumble bee engine with an 8.3 Viper engine like mine while you're at it.....:elefant::dontknow:![]()
Update. Ive been busy. I bought the $16 TPS. First thing i did was reset the PCM. I touched the battery cables together and reloaded the stock tune. Then took it for a drive. Odd but the stock tune even felt stronger after this than the 93 did before.
When i returned i installed the TPS, i pulled the IAC which was pretty carbon'd up as suggested. I cleaned it well and the hole it goes in with toothbrush and seafoam. I removed the CAI tube and opened up the Throttle Body butterflies. Sprayed some seafoam on it and with a toothbrush cleaned up the rim where the blades touch and the butterflies. Probably futile but im anal, just not anal enough to take it off and clean it proper. I then shorted the cables again, and reloaded my 93 tune.
Took it for the same drive on the same route. When i got to the first light and touched the brakes for the first time i nearly ate the steering wheel. Not sure why but it seems i have more vacuum. I also noticed during the 30 minute ride around town, that 90% of the popping and gurgling the exhaust that im used to, is gone. It may pop once or twice then just smoothly growl all the way down to idle. I mentioned before that the truck felt lazy down low. No longer the case. Either from having the tune reloaded, the tps swap, or cleaning up around the TB, the truck feels like a different animal. From a 10 mph dig full throttle lights the tires up all the way through first and halfway through second. It passes better on the highway in higher gears as well. Its pretty suprising.
Now the whole low idle thing. It is idling the same rpm as before, just much smoother now. During my little jaunt around town i watched the tach closely. When putting in neutral and off the throttle the tach hangs at 1200, drops to 750 when idling then immediatly drops to 250 and sits motionless till i rev it. After it audibly gains a a couple hundred rpm, the tach lags behind then jumps up to where it should read. The problem is the tach. Nothing wrong with the engine.
What year is yours? If it is an 06 it is probably a bad cluster. Mine would even read 0rpms driving down the road lol replaced and never happened again
I can get the part number for you if your interested
