JeffBoyette said:<img src="http://www.vtcoa.com/forums/attachment.php?attachmentid=46722"/>
<img src="http://www.vtcoa.com/forums/attachment.php?attachmentid=46724"/>
Its not idling rough, just low and lopey
Whether it'll hurt it or not, doesn't matter Jeff. It's not right. Trying the easy fix and change the TPS. $20 at the auto parts store and a lot of us have had issues with it. Could also bs ur idle motor. But I'd guess at the TPS. They go bad often and don't through codes. You know these motors idle a bit rough, but shouldn't be lopey.
Your PCM is learning its new enviroment (Guessing that you didn't see low RPM's when you picked it up). However, I've been wrong so much I never know any more
If you or Geo changed to an aftermarket Tb there is a small chance the TPS is reading wrong if the new TB throttle stop is a bit different. I would also remove and clean the IAC as it will be covered in carbon. Other sensors also contribute, but the IAC actually does the controlling of idle air. As far as your Viper Tech talking about syncing the TB, tell him there is only one! The previous Gen Viper did indeed have 2 that needed syncing.:rock:
No i did read something somewhere about "syncing" it. Unplugging the IAC valve then setting the base idle. Plugging it back in and letting it relearn. Id have to find it again. maybe someone will chime in. I will take a look at the carbon on that IAC. The throttle body is stock, and doesnt look like its ever been removed.
JeffBoyette said:I did read alot about the TPS. This truck has seen a year or two with less than 1k miles on it. I dont think the fuel would have gummed up the injectors or messed with the throttle body. The vipertech told me one time on my old truck that the throttle body needed sync'd. This could be the case here, but i also agree with you that the IAC valve should be compensating for any restricted airflow at the butterfly from carbon. The dyno on the truck was suspected to be low for the mods done. This was pointed out by Torrie that performed the tune. However, it is possible i guess that if the TPS was telling the computer it was at 80% throttle, it would throw the fuel and timing curves off. The truck seems a little lazy at low rpms, noticed by myself, and commented on by my wife. $20 bucks for a TPS seems like a cheap diagnostic. At 35k miles and 5 years its probably due for a tune up, and im not too confident on this Volant CAI.
The search continues. Opinions/Advice, keep them coming. This is the most knowledgeable forum out there, and a helpful group of ya too. Thanks again.
JeffBoyette said:Temperature and humidity were nearly identical here and Pekin Illinois. Also im at 100 feet and pekin is 650 ft. So the density is about the same. Not enough to throw it off like that. I could try to load the stock tune, unplug the PCM and let it reset to relearn. :dontknow:
Ill put this TPS on, see what it does.. then reload tunes and reset pcm
rbabody said:what u should have done first is hook it up to a scanner and see what the true rpms are then you could also check the tps voltage and read the iac counts/steps if you dont have one go to your local parts store and have them hook up scanner with live data
I tell u what. You mention the volant intake. I noticed a significant drop in performance at the track in the midrange, with the Volant. Almost like a lag. Took it out and put the the factory intake back on with the drop-in K&N and no more lag
