Protect your bumper with towels. The side bumperettes (sp?) too. It the tailgate gets away from you. You'll scratch something.MYuGiOh Motorsports said:the two cables just slide off the posts, lower the tailgate about 30 degrees and it just slides off the posts that hold it on...
Takes about 2 minutes, no tools
Nowwhat said:open tailgate.....call roktman.....have him stand on the endge....presto.........
MYuGiOh Motorsports said:He wants to remove the tail gate....
I don't think he wants to remove the entire back of the truck
OOOOOOOOOH, the pain
Thanks, I plan to take it off next track visit. I was hoping it weighed alittle more, lol. But every little bit helps.Rice Eater said:undo the cable clips.....lower about 30 degrees and the right side of the tail gate will pull out towards you then the left side pops out. to put in....put left side in first then get at the propper angle and fit the right side back in its notch.....be careful i did scratch my bumper! it weighs about 50 or 60 pounds.....i took my tonneau off tonight and will try some runs w/ out the tail gate tomorrow night.
do you think that 12lbs is enough,iam thinking more like 15lbs.TheSickness said:12 lbs of C4 and a long fuse![]()
Ha, I was going to suggest the same thing but mine used a logging chain.Texas Yellow Fever said:...or, you could tie one end of a rope around the tailgate, the other end around a tree, back up as close as you can to the treee, then take off really hard...
rednecks use chains always a log chain close bySilvrSRT10 said:Ha, I was going to suggest the same thing but mine used a logging chain.
eddie102870 said:rednecks use chains always a log chain close by
SWIFT said:Thanks, I plan to take it off next track visit. I was hoping it weighed alittle more, lol. But every little bit helps.
