Stinker said:justin is also working on a bigger blower set up also , one that would work well with larger heads and cams and such.
that might be a way to go also.
i think 505 has a pic of it somewhere
HUH???????
You talking about the Procharger SC Tony?Stinker said:justin is also working on a bigger blower set up also , one that would work well with larger heads and cams and such.
hello joe:ciao:Scrambler1 said:Yep I was the third guy who to experience the Paxton running out of air.
To the original poster... if you leave the heads and cam stock you will make more power with the Paxton, close to 700. If you want more power than that you'll need a turbo and in that case heads/cam work.
TMCNORWAY said:Yeh, bit of head F**k, but i have to point out i'm in Norway and things are a liitle strict with certain things, I will never get away with a turbo. Lucky to get away with the supercgarger.
I have already ordered and paid for most of the parts, so what can i do to the paxton and the mods i have mentioned to improve the power.
TMCNORWAY said:So if i go with the roe charger, can i increase the boost, and will it work well with the rest of my set up
yes these things come apart under boost so forged internals is a mustTMCNORWAY said:so if i go with the paxton, i should still balance the engine go with the forged pistons, rods, comp. clutch and forget the rest.....
TMCNORWAY said:How is the single turbo, what make do you suggest, i really dont think i will get away with it here, the authorities are f***ers.
And what kind of power to expect.
leave the heads alone proloy leave the exhaust manifolds on also might not even go with a custom grind camshaft....just keep the stock one, pistons and rods definately forged and billet mains and cometic head gaskets you will be good to go:rock: :rock: :rock:TMCNORWAY said:Yeh, bit of head F**k, but i have to point out i'm in Norway and things are a liitle strict with certain things, I will never get away with a turbo. Lucky to get away with the supercgarger.
