How to get rid of the seat belt chime?
John02SS
Pensacola, FL
It is aggrevating! I dont' always wear my seat belt although I should, and this thing needs to go for the times I don't. Is there a wire to ground out or something? Thanks.
John
Jumper wire in the plug under the seat
If you read the owners manual there is a section dedicated to turning off the seat belt chime. I did that in my 05QC. I don't have the owners manual here or I'd tell you what page it was on.
:dito: :dito: :dito: :dito: :dito:
The Enhanced Warning System (BeltAlert) can be enabled
or disabled by your authorized dealer or by
following these steps:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. Turn the ignition switch to the OFF position and
buckle the driver’s seat belt.
2. Start the engine and wait for the Seat Belt Warning
Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver’s seat belt at least three
times within 10 seconds, ending with the seat belt
buckled.
4. Turn off the engine. A single chime will sound to
signify that you have successfully completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
NOTE: Although the Enhanced Warning System
(BeltAlert) has been deactivated, the Seat Belt Warning
Light will continue to illuminate while the driver’s seat
belt remains unbuckled
(BeltAlert).
Light to turn off.
buckled.
This is how I did mine...
Did you get the other thing taken care of?
Why don't you irresponsible MOFO's WEAR THE DAMN THING! :mad: :mad:
:D
I do... but when I am going 2 blocks through the neighborhood with a top speed limit of 7 mph... I don't put it on... :D
Just call me a rebel! :D :D
jbilledeaux said:
pm sent:rock:
your avitar looks good.:rock: :rock: :rock:
is there any place where our trucks don't look awesome???:dontknow: :dontknow:
I dont think so, that was taken in Lake Charles, LA with hemibates. Now that sea wall looks like crap after the last 2 hurricanes:mad:
same goes for me.I wear mine all the time but nice when you are close to home or getting to a game ,...... and taking it off with out that stinking ding!
I actually miss my chime. It's been off over a year after my CF clutch was installed by the dealership. :dontknow: I suppose I have to run those procedural steps in reverse..?
i know a way easier way to do this with out all the mumbo jumbo all you have to do is look at the bottom of the seatbeat buckel strap were it mounts to floorboard,, there is a plug at the bottom that hooks to the buckle ,,,all you have to do is insert a small jumper wire to jump the two wires and BAM no more ding and it takes like 5 mins or less
After being rear ended two blocks from home awile back in my wifes car at about 20 mph, I say put the belt on!
First thing cop will ask is if you had your belt on!
Dumb ass was texting on her phone!
WEAR AT ALL TIMES!
...just my 2 cents!
