Does the better airflow help with my boost? It appears to have made it more steady or now the hi-flow are less restrictive so it is harder for the turbo to build boost. Any ideas?[/QUOTE]
excerpt from Dennis Grant...
I've seen a couple of posts from people who added aftermarket exhausts, who report "my turbo spools up faster now" Well, that's because by lowering the outlet pressure, you increased the pressure differential, and now the exhaust gas can expand more, and do more work. That increased work pushes harder on your turbo, and it spools up faster. You should also see less boost drop at redline, because if an exhaust system is flow-limited, once you pass the flow limit of the system, any additional gasses you try and force through it only raise the outlet pressure. Higher outlet pressure, lower pressure differential, less work, less boost.
Ron
