I GIVE UP!!
GRYSRT
Lantana Fl
Ever since I put headers, catless mids, and the catback i've had nothing but problems with my CEL. The first code it was giving me was....P0132-O2 SENSOR 1/1 CIRCUIT VOLTAGE TOO HIGH. I changed the 02 three times. Now when I turn the key forward and back my truck wont even give me the code, it just says done. I just got the 02 sensors from Roe for the down streams and one of them doesnt work. I've done it everything to try and get the CEL off, but nothing has worked. Everything is installed and wired properly. I dont know WTF to do!!
remove everything, box it up, send it to me, i will install it and run with it for a while to see if we can figure it out
Good one!!! :D
give me a run down of what you have,
what has been replaced
I remember some of it
do you have a flash?
simms?
lts or shorties
any cats?
No ! Send it to me. I think it's a problem with it being in Florida and Mutt's in Florida. It needs to be tested in North Carolina.:D
simms?
lts or shorties
any cats?
Everything done to my truck is on my sig......I had the mechanical sims but the I got the electric ones from ROE. I' ve talked to a couple of people that have the same set up I do and they never had any CEL problems. I think that my truck is retarded. Everything I installed was done right
I don't even know if it's matters or even possible but are all the O2 sensors where they're suppose to be. I mean are the rear O2's different or identical to the front O2's? Is it even possible to mix them up?
Outside of having a PCM--that may or may not have the 02 sensors disabled, I have sims from www.voodooboost.com
At $25, could be an easy fix:dontknow:
ok...........you replaced both o2's
simms on rears, no cats, no flash.
I had the same problem with my qc and it wouldn't pass emmisions.
I got two new o2s from dodge bought $25 each
rechecked and soldiered the wires on the sims instead of crimping.
also went by the dealer to ckeck for updates,they had a download for the evap system causing weird stuff.
problem was fixed, don't know if it was the download or soldiering the wires.
you might also think about the mopar pcm, I hear it cleans up a ton os stuff also
Where can I get a mopar PCM?
Double check that the mopar pcm will work with your 06 truck. If it doesnt my DC Perf pcm has worked magic for me...........call em!!
Either way you'll get some more power and get rid of those cel's.
ViperTruck2933 said:
People who can't spell people are retarded too. :p
:D :D :D
zzzzzzzzzzzyou would have been lucky to still be upright to post that well . After all the Shit I smoked that night LOLOLOL So I will gladly take the spelling error and take another Bong rip in your honor :D
