I have $3k to waste
u think my truck will ever run like yours since its a 06 and its heavier?
what mods do u have exactly...Im trying to do full bolt ons ...I want something reliable
I have bassani headers, cat less mids, bbk throttle body, k&n drop in, magnaflow cat back, and a tune. And extensive weight reduction. Are you planning to roll race or run at the track more?
JTS Venom TB it's already tapped for the nitrous nozzles, a set of long tubes, nitrous and tune. Should put you right at $3k
I'd go with l t headers and a u d pulley and rest of the 3 k in fuel cause after those mods you won't want to get out of the truck
Headers (Bellenger or mopar)
Throttle body (bbk)
Under drive pulley
Spec clutch stage 2 and aluminum flywheel
what should it be running around in the 1/4 with those mods and the mods i have?
If you use it to go back and forth to work and a daily driver ,long tube header catless mids ,JVS TB ,and a good Dyno tune will get you 460 to 465 RWHP.Don't worry about fastest times at track ,most of the ones with the fastest times at track have the most brokedown truck also ,do just enough for you to enjoy it without having to fix it all the time
personally i would do n20 and some suspension upgrades talk to justin@ jmb performance he has built the fastest n20 truck and the fastest srt 10 period!!
I totally agree with Brad,Talk with Justin-JMB and he will take care of you and get you going in the right direction and has a fantastic record that no one else has, with proven results!!:rock: (Look at Justin's sig):rock:
Throttle body (bbk)
Under drive pulley
Add a good tune and offer a Roe single blade as an option and its all good!
A good set of fresh oem plugs and low resistance wires as well. Tune to suit mods :)
N2O only lasts as long as your fill! Your back to slow and stock without the juice ;)
i put belangers, high flows mids, JTSVP coils and wires, fresh plugs since i was in there, and a canned SCT tune from Torrie all at the same time... dropped my 1/8 mile times by over a half a second.
i added the carbon DS and it helped a little, too (but that was later)... and yes... it's still available;)
