Blaine@PSI
well im not to sure about this just yet but other things have sparked my interest. SO the Lightning must go in order for those things to happen. the list of goods is pretty extensive so ill try to list everything but i may forget some.
2000 Ford Lightning with 34K miles total
fully caged for 9.99 runs with harness and corbeaus
AMS 1000 boost controller mounted with Co2
all rockers mounted
NO A/C or HEATER
very streetable and I do drive it to car shows and such
QA1's all the way around with JLP 4" shackles
Belltech spindles and JDM drag springs
new brakes factory spec
JDM long bars
new BTS with new converter from PI
new motor has only 5 heat cycles and no runs
short block consist of manley rods and pistons with larger wrist pins
polydyne coated skirts and tops also stainless rings and gas ported pistons with Trick flow heads that have been cleaned up and is set at 9.3to1 comp ratio
Custom PSI Motorsports turbo kit with Precision Turbo PT88mm with 4" aluminum down pipe. custom headers that have been jet hot coated and stainless crossover with Tial Race 50mm Wastegate, and Vortech Mondo bypass.
custom intercooler resv and no h/e
has a dynojet wide band with datalogging
boost gage
line lock
15" bogarts all the way around with new tires on front and 8 passes on slicks
ABS delete, airbag delete, radio delete, hvac delete all to make the truck as light as possible. custom rear weight bar
rearend has trutrack with 3.55 and JDM girdle
all 01 up lights all the way around including 3rd bl
antenna delete with upr stud
ful PSI/FORE fuel system including 3 pump hat and 3 walbros, -10 line, fore regulator, aeromotive rails, custom 78lbs inj, custom maf.
contact blaine at 713.503.4514 for more info no offers for trades cash only
I'm going to offer the truck in 3 configurations
1. truck only track ready 28,500.00
2. Truck track ready with trailer and gen 30,000.00
3. truck track/street ready trailer/gen with HRE wheels pictured 34,000.00
truck made 1067hp on moderate boost at 25lbs. still more in it. needs absolutley nothing to go racing or driving
all rockers mounted
NO A/C or HEATER
JDM long bars
boost gage
line lock
