IAC and MAP sensors installed .. both original factory parts came off ...
P retty straight forwad on the dakota ... minor diddles with getting the tools right .. IAC s mostly by feel in its location ... MAP didnt like my torx bit and threw down behind the alternator.. luckily I did retrieve it ..
Afte the IAC I forget to reset the codes and tool it for a drive .. got back home and and tested ... WELL SOB 0432 was back . With the still 0455 ..
I need to tie up the wore from the 02 sensor as it had droped on the exhaust again .. should be a simple fix hahahaha ok , whatever I say hahaha ..
Thenold parts are filthy but the IAC I believ was sticking . After the new one was installed the idle was high but settle down after a minute or so . My guess is the computer releaning ..
Test drove it after testing codes again and no codes showing , YET ! need to drive it a little more and test again ....
Found another dried out cracked hose that relates to the EVAP SYSTEM and maybe thats trowing the 0455 code .. ill need to get around 2 ft. of 1/4 inch hose and replace it .
I also charge the A/C with a pound of the 134a refrdgerant but need to get a sniffer to find the leak ... then more expense for a set of gauges and a vac...
Its one thing after another to get this hing completed ..l I keep adding things to do that dont really need to be done .. IM JUST BORED HAHAHA
