Hello,
i am new to this forum and seems i start directly with a problem.
When i start the engine of my 2005 SRT and it is cold, i have no idle.
I have to stay on the pedal and keep the rev up until the engine gets warm.
When it gets temperature, the rev do not stay at a constant level, they go between 300 and 700. As soon as normal temperature is reached, all is fine and no problems.
I checked error codes: nothing. Also air temp sensor, coolant temp sensor give correct values (at least i think so. when i start the engine cold, they give exactly the temperature like it is out side and then go up).
Also i found no hoses, connectors or anything that is loose.
Only mods that i did is a k&n filter and magnaflow catback. But the problems had beed there before already.
Any idea that could help?
Regards
Steffen
Regards
Steffen
