I should be getting my rear leveling kit from Stinker tomorrow. Is there anything special I need to do or look out for when installing them? Or is it pretty straigt forward? Thanks as always.
not too bad to do.SANTEEN said:I should be getting my rear leveling kit from Stinker tomorrow. Is there anything special I need to do or look out for when installing them? Or is it pretty straigt forward? Thanks as always.
yea santeen if you need any help send me a pm I'm not too far from you and I'm willing to help!SANTEEN said:I should be getting my rear leveling kit from Stinker tomorrow. Is there anything special I need to do or look out for when installing them? Or is it pretty straigt forward? Thanks as always.
LIttle trick, raise up the rear just a touch, get some of that PBJ I think it is, at home depot is where I get it on the east side, and jsut soak it as good as you can,NorCal SRT-10 said:FUCK! I forgot the grease mine up when I installed them. Looks like I'll be down there again soon. Maybe I'll order some Cal tracs so I don't feel like I'm doing the same thing twice.
don't worry, you're not alone....i ran out of grease in the gun on my second one, and had no way to get any, so now I have the annoying squeak from it. so if i go down there again it's to grease and remove overload spring like EMTNorCal SRT-10 said:FUCK! I forgot the grease mine up when I installed them. Looks like I'll be down there again soon. Maybe I'll order some Cal tracs so I don't feel like I'm doing the same thing twice.
If ya'll guys need some of the slippery stuff, I have some from energy suspension that works great in small tubes, now I mean its a small little thing, but it works and stays really well, if so , send me a pm with your address and will ship you a couplekickinassrt-10 said:don't worry, you're not alone....i ran out of grease in the gun on my second one, and had no way to get any, so now I have the annoying squeak from it. so if i go down there again it's to grease and remove overload spring like EMT
Right on! PM on the way.Stinker said:If ya'll guys need some of the slippery stuff, I have some from energy suspension that works great in small tubes, now I mean its a small little thing, but it works and stays really well, if so , send me a pm with your address and will ship you a couple
No, it's the Belltech shackle kit.SANCHOBA said:are they lowering blocks?
gunu said:what is the exact length of the drop shackles. i purchased my truck used and not sure if it has them on there already , it looks a little lower than stock but not sure if the original owner had them put on, any help would be appreciated !!!
Stinker said:LIttle trick, raise up the rear just a touch, get some of that PBJ I think it is, at home depot is where I get it on the east side, and jsut soak it as good as you can,
but the newer ones dont seem to be bad as the first ones that went out
thats th one prof, thanks , I knew there were two different onesProf said:Tony, tony, tony...
Its PB Blaster...penetrating spray...
PBJ is also slippery but it damages things, PB Blaster helps to fix things...
I know of a couple of people that are going to flame me for that comment, but its how I feel!
