Installing T-stat, Need checklist
Stinker said:
Call Justin and get some real clamps guys, NBT just had his blow off because of the lame factory clamps.
Well while your at it jsut get a set of hard hoses from Justin:burnout:
Just not pink like rice Eater:D
I got to tell you though...it's only 16lbs.... WTF? Should take more than that to blow off the hose/clamp:dontknow: ... would have thought so anyhow.
FlyingLow said:
There is a bleeder valve on the bottom of the radiator on the drivers side. You can attach a small hose to that and drain it straight to a bucket.
Removed about 1 gallon.
Remove FOUR bolts from T-stat Housing. The bottom one, towards the middle of the engine, is the tough one
Remove housing and swap T-stats.
When re-installing the housing, start with the 'tough' bolt. The T-Stat housing uses a reuseable O-Ring, so no gasket or sealer is needed.
refill cooling system.
Start truck and use bleeder screw on top of T-stat housing to bleed out air. Only have to loosen it a little bit, when straight coolant purges out - you're good to go. Tighten it back up.
Might be a good idea to have some extra coolant to top off the system when finished.
I copied the above info from other posts. Hope it helps.
very nice, thanks.
