ram_vs_cougar
I want that setup sooooo bad!!
Yeah me to Fatjack. Time to start saving up bud..:rock:
It sure is tempting. Its not the plan I had in mind but with numbers like that now thinking hard on it. Justin you have any info you can send me as far as you installing it and any other recommendations.
Hey Justin what all internal engine up grades will one have to do for a set up like this. I know the tranny will need up grades and rear axel for drag slicks or radials.
for what...you're broken truck![]()
I will PM you
The system can be pullied to produce whatever boost you desire (within reason), so if you want to run in on 5-8psi and stock internals/trans/etc. it should provide no issues assuming you have a good safe tune. Obviously anytime you modify any vehicle beyond the stock power level there is a higher chance for failure, so this needs to be taken into consideration for any power adding modifications. To achieve power levels near/equal to Johns truck you would need at bare minimum a built trans, forged pistons/rods/head studs/etc. The rear axle would be dependent on the tire used, and the engine would certainly benefit from ported heads, custom cam, billet mains, etc.
@yellowfever#154
Thanks for the info. Yeah 850 would do me well LOL. Id rather go with the serpentine setu as well. Was is just roughly 10K for just the kit and extra parts you have ? Were you already forgerd from the jump or stock? etc....
2 bad you don't rock yet Joe lmao .....
Yellowfever#154 and i have identical builds,fully forged and ready to rock!:rock::burnout:
@yellowfever#154
