VNM PWRD
So I received a Stage I traction kit from Prof :rock: ...... Not enough clearance to install the part that comes in contact with rubber boot at the end of the slapper bar :dontknow:
VNM PWRD said:So I received a Stage I traction kit from Prof :rock: ...... Not enough clearance to install the part that comes in contact with rubber boot at the end of the slapper bar :dontknow:
WILDMAN said:I had to take a pry bar and push down on the springs to make room. It should fit tight. Just push the springs down and slide it in.
Wade
Prof said:Did you get the instructions I mailed via snail mail? Justin mentions this issue in the instructions...use a breaker bar to gain the clearance needed...
Justin, this may just be an issue of me not mailing the instructions with the parts. I neglected to put the instructions in the box, then mailed them a few days later, via the post office (stupid me...twice...not putting in box, then using the post office, our most archaic governmental institution).
NOT A JMB PROBLEM....another Roy problem![]()
VNM PWRD said:Thanks guys .... I will get it done friday.
Hey Eddie ,Whitesnake said:hurry up, and that pic's!![]()
VNM PWRD said:Hey Eddie ,
Are you going -------> http://www.vtcoa.com/forums/showthread.php?t=11919 :dontknow:
Gaboon said:Just not thinking outside the box, HAYOOOOO:star:
Prof said:OK, credit those to whom credit is due...cute comment! But no one would blame VNM if he slapped you up side the head.
