JMB Traction kit not working on My 06
VNM PWRD
Hollywood Ca
So I received a Stage I traction kit from Prof :rock: ...... Not enough clearance to install the part that comes in contact with rubber boot at the end of the slapper bar :dontknow:
Have you tried calling Justin at JMB about it.
Pic? :dontknow:
I will try and get some pic's up by friday .... Have to drop the truck off at the body shop they left a bunch of over spray.
WILDMAN
I had to take a pry bar and push down on the springs to make room. It should fit tight. Just push the springs down and slide it in.
Wade
Wade
Exactly, you are preloading the bar slightly.
Justin
Did you get the instructions I mailed via snail mail? Justin mentions this issue in the instructions...use a breaker bar to gain the clearance needed...
Justin, this may just be an issue of me not mailing the instructions with the parts. I neglected to put the instructions in the box, then mailed them a few days later, via the post office (stupid me...twice...not putting in box, then using the post office, our most archaic governmental institution).
NOT A JMB PROBLEM....another Roy problem:( :( :(
My guess it's related to your age.;) :p :D
I just jacked the truck up to take the weight of the rear suspension and it fit right in.
Bill.
Just not thinking outside the box, HAYOOOOO:star:
OK, credit those to whom credit is due...cute comment! But no one would blame VNM if he slapped you up side the head.
Just recived them ..... thanks Professor:D :D :D
No I wouldn't. I will take a beating when one is due. Slap away.
