JMB, Viper slave/master install with stock clutch
chromecards
Well I'm back to a stock clutch with the JMB Viper slave/master cylinder install. I just wanted to post this to thank Justin.
The install took about 6 hours for me, my brother, and father to complete.
So far I have had no problems, I'm going to break in the clutch, 500 miles, 440 left, and go from there. I have had none of the prior issues with the clutch slipping and burning while in traffic or pulling into my garage at an incline. I have had it in situations where before with the Centerforce, it would have slipped and burned.
Also I checked the Centerforce disk when we pulled it out and it does have quite a bit of life left. However it was actually in worse condition then my original stock clutch disk. The Centerforce disk had lost twice as much material when measured agianst a new Centerfoce, as the original stock had lost against the new stock. The original stock had 5500 miles and the Centerforce had 7500 miles. I was very suprised to see this because the stock clutch had a major clutch burning incident a few days after I bought the truck.
What we did notice is that the Centerforce presure plate was in fairly good shape. It had a few minor burn marks. The orginal stock presure plate was burnt to hell, it had burn marks all over it.
We debated using the Centforce presure plate with a new stock disk combination, but decided against that for now.
My original problem of not getting the truck in reverse when it is at normal engine temp is now gone. I believe it was attributed to the clutch not releasing due to poor hydraulic pressure.
I just wanted to thank everyone for their input and advice with this problem, and the previous problems I have had with the truck. And a big thanks to Justin, JMB.
Russell
Exactly what I am doing, Viper hydraulics, OEM Clutch and pressure plate, will know how I like it next week.
That's what I have due to typical probs. Dealer replaced clutch/flywheel at 6500mi./18mo. under warranty (even though it was technically out), but no go on the hydraulics as they showed no signs of problems. Got them to replace Hydraulics while they were in there with upgrade kit I purchased from JMB, but wouldn't put the C.force in due to the warranty claim on the stocker unless I wanted to pay the entire labor bill!
2k on since, feels same as it did on orig. when new (which was good) and no probs yet!
