DRamSrt10
hey y'all i did try key-on three times and it show the code and it said P 0442 any idea what is that code means?
bucke77 said:evap leak... check gas cap, if loose tighten, if not probably NVLD pump or split hose to NVLD...fix em all the time
is it under warranty? if so take it to the dealer. its part of the evap system. NVLD is natural vacuum leak detection device that performs a test for one of your monitors (EPA shit). or typlically one of your evap hoses is split causing a loss of vaccum when this test is run (hence a failure in the monitor and check engine light)DRamSrt10 said:i did check gas cap and it was not because of it, also what does u means by NVLD? i dont undy what is nvld pumo and spilt hose?
you'll be fine. no goodluck needed.DRamSrt10 said:ahh thanks man, i will need make an appointment and see dealer...whew wish me a good luck
