Does anyone make a larger throttle body?
Ummm... already done. Choose Roe or X-Metal. Both work.blackviper said:Yeah, it would be nice if someone would come up with a larger billet throttle body.
Stinker said:BBK has a prototype, but made no more hp, exotic tested it i think
FSTJACK said:It did make more HP, how much more, and where I don't remember.
It is a larger 2 blade.
I will check next week after after everyone gets back from VOI.
Stinker said:dang my mind is shot i was thinking it didtn , my bad
Can you give a link to the ones you have seen? I am trying to make my own as documented here http://www.vtcoa.com/forums/showthread.php?t=26341JimTeTe said:Does adding a TB spacer do anything for these trucks? Since a larger TB is asked about, would a spacer improve HP or performance in some way. I see them advertised for about 90 bucks.
Thanks
Jim
blackviper said:Anyone else with any feedback? It would be easy for us Roe guys to bolt up a bigger throttle body. The only modification we would have to do is match the opening on the plenum to that of the thottle body. I think this would cure the issue that 700hpodyssey had pulling two inches of vacuum on the filter side of the throttle body at 14PSI of boost.
I get the metal in tomorrow. I will be able to start the machining on Friday.Stinker said:Fstjack had all the info on this guys, maybe he will chime in and give us an update on the BBK
Tiny, hope the spacer is going well:rock:
MikeNice said:No price?
