NukeGM/Ford
ok, still working on Zilla, guess its my turn to get a cot in the garage………..
1. started coils and wires and plugs
2. had to remove intake for coils and wires and plugs
3. figured i better do headers before running wires
4. realized i needed to run the wire for the battery re-location
5. the re-located battery tray hits the bolt/nut on the rear of the pass leaf spring
6. needed to flip the bolt/nut around to clear the tray
7. couldn't get the bolt out with taking the spring completely off the truck
8. bolt/nut flipped, now i can't get the front spring bolt back into the hole to remount the spring. i changed the springs on my Charger 15 years ago and it was easy……… i'm forgetting something……… there must be a sequence to getting these holes lined back up…….. i can't remember it……. everywhere i search they don't actually show installation of the bolt, it just magically appears
9. can someone tell me what i'm doing wrong so i can get back to step 5, then 4, then 3, then 2, then 1…………. then i can start all over again with the traction system, lowering kit, shifter…………
oh yeah, the Venomous1 throttle body looks great sitting on the bench by itself………………….:stupido::stupido:
