Fahrenheit
Yeah, Im a big dummy, I need instructions to install this.........didnt get any with my box I got today.
Fahrenheit said:Yeah, Im a big dummy, I need instructions to install this.........didnt get any with my box I got today.
Attach the ground wire to one of the line lock mounting scews with an eyelet connector. Power wire to a switched source through the momentary switch. And dont forget to bleed the front brakes. It's a pretty easy install.Fahrenheit said:Thanks for the info, the only thing is where the wire are best hooked up to (electrial componets are my weakest link)
its simple really, get stinkers lines, bleed the brakes and wire it up, kevan goes overkill on his DIY's but they are thorough...lolFahrenheit said:Now Im really confused after reading Kevans write-up.............
OSO said:Since he is an auto could he benefit more from installing the line lock on the rear lines to block pressure to the rear brakes while the brake is applied . Giving him the ability to control forward roll as he is doing his burn out?
eddie102870 said:its simple really, get stinkers lines, bleed the brakes and wire it up, kevan goes overkill on his DIY's but they are thorough...lol
Can you elaborate on this?FSTJACK said:That is a really bad idea.........
