Alright I got with Stifflers performance that make the long traction bars for the Lightning guys. The price would be 495 and we'd need about 20-25 guys for them to do it. So I'm just wanting to find out how many would be interested in them.
When the dead line to pay up
Sent from the Harris County Jail
I maybe interested , I'm just not going to go into them blind .. I would need to know if they are going to be an improvement over Cal-tracs . Considering the price is more than cal-tracs being un-tested makes me shy away from them at the moment ...
How do the Stifflers attach to the axle and frame?
Glad to see someone run with this.
Frame mount:
Axle mount:
These things are gonna bind! There are different pivot points which will cause the pinion angle to change with every suspension movement. The geometry isn't right! Am i missing something?....
There are pivot points front and rear on the bars were they bolt to the mounts and they wont bind. If they did they wouldnt be on 10, 9, 8 and 7 second L's. They work and work much better than caltracs on L's and I think it would be a safe assumption to say they would work better than caltracs on 10's.
Just out of curiosity whats the best 60' a caltrac equipped 10 has achieved?
According to the time slip section .... FatJack with a 1.53
is it a set up that can be used on a DD????:dontknow::dontknow::dontknow:
The whole idea with Caltracs and/or longbars, is to stabilize the diff from spring windup! the caltracs work great on the 10 . the wheels don't hop from spring windup once Caltracs are installed and properly adjusted . just from tire windup. our trucks are really heavy! so things will take stress until it gets moving!! If the longbars work great on lightnings then maybe their springs are softer so less noticeable conflicts . the caltrac has the bar the same length as the spring from center of axle to center of eyelet. there is very little conflict when the axle travels it's limits. The longbars will have to flex to maintain correct length during suspension travel. The"ladderbar " was all the rage back in the day until the 4-link was invented. The caltrac mimicks the 4-link . ....my 2 cents
