Bravo
04RC 3,300 miles.
Had the truck on the lift to put on some baby step mods (Bassani shorties and magnaflow cat-back), and noticed some oil leaks: Now I know why I had that fried clutch sandwich smell last launch.......
1) the cooler lines. Fittings on the block are leaking. Hoping a little tightening will help.
2) Appears to be rear main seal. Damp around the bellhousing. Removed the inspection cover and .....shit....wet black clutch bits and golden oil up high.
The dealers here are not viper techs. I really don't trust them. I'll just get the truck back with a gob of permatex and a few new door dings from their lift. The local dealers give all techs a bad name. Thank God for this site.
Techy questions.
Tranny removal. how to disconnect slave line? Shifter....remove from underneath ok?
Rear main. Does it come mounted to the plate like gen 2 or do you install it into the plate? Oil pan removal required (sure doesn't look it)?
Do you need to undo the mounts to rock the engine back to remove the bellhousing? or is there clearance to tilt it back a smidge without fearing the damper hitting the rad, etc.
Any known tricks? I'll replace the clutch, but should I do a slave update too and can you update the slave without the clutch master?
Thanks for any and all help. I'm going to do it. Just want to hit it eyes wide open.
-Jeff
BTW - the exhaust manifold to cat bolts on the stock exhaust hurt me. No ox for the torch, so penetrating lube only and those wimpy rusty MF'n clip nuts just made it harder than it has to be. Lots of new swear words....
Techy questions.
-Jeff
