lowering kit swap?
JTS VENOM PERFORMANCE said:
yes they will perfectly, the will be a little shorter, about an inch
Thanks Tony ...... Trying to see if I can help out Eli in a few weeks.
Jim
kickinassrt-10 said:
No it's not from what I know.. I just bought 2.5" shackles off fleabay before I even knew about this site...
So would the rear springs need to be swapped or just the hardware to mount the leaf's on the bottom and the shackles? Basically only needing the front springs swapped?
jsut the hardware from the rear, not the whle leaf spring, jsut the shackles the flip kit ,and the shocks
the front you need to swap the springs
why dont he drive to my house, you drive up here
we will swap both over , no charge except you guys buy the beer and pizza:D
Thanks Tony! Seems pretty easy and straight forward. I'll see what Eli comes up with since my truck is my DD and I have to do it in one day on the weekend!
Ill probably get right on this project when my bee makes it back from texas in about 10 days, then Ill have something to drive while its missing all the parts. Ill pull everything they have told me to , ship it down, then the weekend you do the same , then you only have yours down for a day while you do the swap :)
