i think an older member did, and had a few problems, but they have a ton of stuff and knowledge
Stinker said:they are strong FASTFOOD the problem is with NOS, the deisals dont have quick line pressure response or the need for it, when they transfered the tranny to ours, it was never addressed therefor with nos the problem occurs, the tranny cannot kick up the line pressure quick enough for the trq of the viper engine.
The tranny is allready using synthetic, ATF+4 is synthetic, its just the older tranny's had a different material of clutch and those would slip
FSTJACK said:Heat is your automatics worst enemy.
As Bone's chart showed;
For every 10 degrees over 212 the life of the trans fluid is cut in half;
At 212 degrees it is good for approx 100,000 miles
At 222 degrees it is good for approx 50,000 miles
At 232 degrees it is good for approx 25,000 miles
At 242 degrees it is good for approx 12,000 miles
At 252 degrees it is good for approx 6,000 miles
At 262 degrees it is good for approx 3,000 miles
At 272 degrees it is good for approx 1500 miles
At 282 degrees it is good for approx 700 miles
At 292 degrees it is good for approx 300 miles
At 302 degrees it is good for approx 150 miles, in reality it is dead and unless serviced immediatly, so is your transmission.
At 312 degrees it is good for approx 75 miles
At 322 degrees it is good for approx 37 miles
All that needs to happen is the temperature needs to get to that temperature once, and it's usefull life is over.
Also when you have any kind of slippage (slow shifts) the fluid temperature in the immediate area surrounding the band or clutch pack can spike to very high levels. (over 400 degrees) This again shortens the ATF life.
Keeping the transmission cool is critical to making the transmission "live".
Deep transmission pans, additional coolers run in series with the stock cooler are all helpful to keep transmission temperatures at reasonable levels
As was mentioned earlier in this thread, shift kits and frequent band adjustment all help.
These are heavy, high torque, high HP, HotRods and what works on your mistresses Rolls won't work on the QC trucks................
With that being said there is still no guarantee that something will not break, but I'll take my chances with regular maintenance and sensible modifications.
Not driving it like you stole it also helps. Everytime you put the pedal to the matt it is like pulling the pin out a little farther on a grenade.
This can and will give you a chance at reasonable transmission life.
shade said:OK so bringing the line pressure up seems like it will help.
So this could be done by
a shift kit
or ECM flash or program
We on board with that?
Next would be a better governor (not that I know what that does )
OK waiting to hear back on what you find. Thanks for the great info!
bigike said:A shift kit will not address the plates not being machined correctly...........
A worked vlv body is the way to go. 375$ and the shift timings are improved, everything is re machined to near perfect tolerances
FASTFOOD said:Not to sound like an idiot but don't diesels put down more torque than gas motors. So they should have made these to handle the pressure of a 125 shot of nos?
