I went with Industrial "rubber" hoses good for 3250 p.s.i. using the factory-style fittings.
The upper swivel hose off of the pump (1" fitting) has a problematic teflon swivel-fitting that was eliminated and silver-soldered with a rigid piece installed there and eliminated the swivel . $78.00 total cost, at an Industrial Hose joint.
The system relief on the ps pump is set at approx. 1600 p.s.i. so if the hoses aren't rated that high, they could/will eventually rupture if the pressure exceeds the hose's safe pressure limit.
Size matters (as they say
) and the power-steering feel is based on pressure AND flow.
A small(er) hose will change the feel through the wheel.
