sinus19
- Joined
- Sep 5, 2014
- Messages
- 589
- Reaction score
- 0
Hey guys.
So it seems that i have a miss a fire on cylinder 4. I went ahead and changed the plug and wire along with the coil. I also swapped injectors and checked compression. Eveything turned out GOOD but the miss fire was still there. after extensive driving it turns out that it miss fires only between 3,000-4,500rpm (only while its underload) with a chatter noise coming from the valve cover. Also its starting to burn a bit of oil... I was told that the cam shaft position sensor can cause a miss fire but that dont explain the valve cover chatter... I will remove the valve cover and inspect but i wanted to hear wat you guys thought.
