Streetgang
:dontknow: Thanks upfront again....Is there a difference between MOPAR ATF+4 and any other ATF+4 ?
Streetgang said::dontknow: Thanks upfront again....Is there a difference between MOPAR ATF+4 and any other ATF+4 ?
bucke77 said:where have you found ATF4 from someone else? as fat as I know ATF4 is still only available through Mopar
who makes itRedSrt007 said:Autozone....Picked some up few weeks ago for the jeep crawler...
good question...let me run in the garage a check..brbbucke77 said:who makes it
very interesting, what do you use in your manual transmission ?FSTJACK said:I had a phone conversation with an engineer from Tremac Corp who builds the T56 trans in the RC trucks. He told me that Tremac will no longer warranty the transmission to Dodge beacuse of the fluid used at factory fill, and fluid Dodge recommends.
Tremac specs GM syncromesh, or an ATF with a D4 rating.
The shifting is much easier.
Many of us ran ATF in manual transmission starting in the 60's, with very good success.
i noticed in your sig that you use "EBC Drilled and slotted rotors with yellow pads"...... has that eliminated all braking noise ? i hate the stockers, they make noise.....RedSrt007 said:Autozone....Picked some up few weeks ago for the jeep crawler...
moparracing said:i noticed in your sig that you use "EBC Drilled and slotted rotors with yellow pads"...... has that eliminated all braking noise ? i hate the stockers, they make noise.....
