Cablefed
I bought a Mopar ECM off a member here and the install is pretty straight forward. I disconnected the negative battery terminal prior to install, hooked everything back up to the new computer and reinstalled the negative battery terminal. When I go to start the truck the truck will not run for more than 5 seconds then shuts off. I'm clueless at this point? I double checked all my connections and everything is good. I went ahead and put the stocker back in and it runs fine. I assume the computer is no good?? :dontknow:
Any help would be appreciated. Cheers!
