Mopar Oil Filter: 05037836AB
Discussion in 'General Discussion' started by mccubbinsjl, Feb 11, 2022.
Car Parts
  1. mccubbinsjl
    mccubbinsjl Full Access Member
    288
    Aug 2, 2011
    H-Town (sort of)
  2. GSJake
    GSJake Active Member
    198
    81
    Feb 13, 2018
    Yep.
    Srt10650 likes this.
  3. beastmode1
    beastmode1 Full Access Member
    565
    334
    Oct 2, 2014
    Denver, CO
    Looks like it but would double check that motor is big bucks to screw around with a wrong filter. I will check the Part # when I get home as I got several Viper oem filters at my garage.
  4. Bad Azp Performance
    Bad Azp Performance Member
    56
    43
    Nov 9, 2021
    Las Vegas Nevada
    836 is the white viper filter
    099 is the black service filter
    Either works, black is half the price of white.
    Having said that, i use the 836
  5. 96indyshaker
    96indyshaker Member
    40
    23
    Dec 16, 2018
    Auburn,Indiana
    So I'm getting ready to change the oil in my 10 after sitting all winter. I was thinking I should pull the fuel relay and crank her over to get oil pressure up before firing it up. Does anyone know which relay I should pull?
  6. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Relay numbers vary year to year.
    The simple way is to hold your throttle to the floor THEN crank the engine over. Keep it floored while doing this.
    The ECU will go into "Clear-Flood Mode" and shut off the injectors. This goes back to the day of Carburetors and how to clear a flooded engine with those.
    It works with a great many fuel-injected vehicles, not just the SRT-10.
  7. 96indyshaker
    96indyshaker Member
    40
    23
    Dec 16, 2018
    Auburn,Indiana
    Thanks ronnie.
