SRT2SLOW said:so what do you recommend for a mostly stock with 22k....i also live in the north east?????? i did my first oil change with 0-40 and i notice the valves are a lil louder...will the 15-50 work for me????
I do not think the 15-50 will flow well enough in cold temps. Try 10-40 first, And see what you think. Start up is what kills you in cold climates.SRT2SLOW said:so what do you recommend for a mostly stock with 22k....i also live in the north east?????? i did my first oil change with 0-40 and i notice the valves are a lil louder...will the 15-50 work for me????
JRSVIPR said:I do not think the 15-50 will flow well enough in cold temps. Try 10-40 first, And see what you think. Start up is what kills you in cold climates.
SRT2SLOW said:what you guys think about royal purple????
Ironhead said:just changed my oil today after work ,,,15-50 mobil 1 baby,,,i even dropped the filter in the bucket of oil and it splashed right in my left eye BLOOP ,,,so truck is oiled up and so is my eyeball![]()
I run Joe Gibbs also. My machine shop told me to run there break in oil for 200 miles. Then go with XP4 for 500 miles Then XP6 after that. I should be ready for the dyno the week of 4/5.Yellow venom said:I run Joe Gibbs racing oil,just thr break in oil now.
Hey Jack,how long should a guy us the break in oil for? till it gets dynoed?
FSTJACK said:So is this the first time you used the 15-50 ?
Ironhead said:no sir last time i changed oil i started using it ,,before i was using the 40w mobil onewhen i installed the harland roller rockers ,,they were a tad bit noisier than the stock rocker arms so i went with the 50 and it quieted up a lot
So, living in Florida, you would suggest that I use 15w-50 or 15W-40 in my stock motor with a Paxton?FSTJACK said:With a blower I would run a minimum of 15w40, I used 15w50 when the motors were stock in my trucks and when we went into them to build they were perfect no wear anywhere.
The heavier oil gives you more bearing cushion and shear strength.
I just don't like the thinner oils on any hotrod, and these are hotrod motors.
On my 04 6cyl ranger I run 10w30 as it is stock and a lopo motor.
The Zinc has all been removed from all passenger car oils. If you have an older motor with a flat tappet hydraulic or solid camshaft you need to run racing oil or us an addative such as comp cams zinc and phosporous.
The racing oils with zinc cut down on the scuffing of the lifter bases.
The reason for the zinc removal is it supposedly shortens the life of the cats. (cough cough)
SANTEEN said:So, living in Florida, you would suggest that I use 15w-50 or 15W-40 in my stock motor with a Paxton?
I'll try the 15-50 at my next oil change. Does Mobil 1 carry this weight?FSTJACK said:I would use the 15-50 if it were mine.....![]()
