TheMoparConnection said:quad and reg cab are different
My engine is on it's way out, if I get one now I will have time to build it before the current one blows. (I am make 10 psi of oil pressure at idle)kyle's srt10 said:Why you looking for a engine block? Are you looking at this:burnout:
http://cgi.ebay.com/ebaymotors/ws/e...m=220180940939&ssPageName=STRK:MEWA:IT&ih=012
wait What do you mean they are different??TheMoparConnection said:quad and reg cab are different
Eh, what? Please explain!TheMoparConnection said:quad and reg cab are different
Annu Kumar said:wait What do you mean they are different??
BigRed460 said:Size 19, but yea basicly stock. 22,000 miles. 10 psi is warmed up @ 750 rpm, I put a second gauge on it to verify it... We were going to do a quick rebuild on this motor but my uncle to me just to find a used one, build it how I want it, and the swap it. Then he will take my old one, build it how he wants it and put it in the viper... With any luck i am hoping for about 650 rwhp n/a...
Chuck B said:Dodge knew that anyone who purchases a QC really isn't looking for performance. They think they are but deep within their brain is a dominant (defective) lobe called Practical Lobe which is just under the Occipital Lobe.
To be fair most of the population is, imho, 'afflicted' with this dominant lobe. How else can you explain Kia, Hyundia and soon to arrive Smart Car. Interestingly enough Psychiatrist have determined that those who purchased vehicles like the SRT10 QC often spend hours pontificating the performance aspects of their vehicles while also spending enormous amounts of dollars to make it 'faster'. I could go into the many medical based reasons for this behavior but to keep it simple I refer to it simply as 'Small Dick Syndrome'.
Hope this helps.....![]()
Thats what I did, gauge read 9 psi, I'll do it agin and see what it makes a 3,000. Either way I know it's coming soon... I can't seem to sell it, so if I am keeping it I am going to continue to race itTheMoparConnection said:I dont really know what the difference is between the blocks.. but they have different part numbers...
as far as your oil pressure...10psi @operating temp at 750 is normal--
Remove oil pressure sensor (Refer to 9 - ENGINE/LUBRICATION/OIL PRESSURE SENSOR - REMOVAL).
Install oil pressure gauge.
Warm engine at high idle until thermostat opens.
CAUTION: If oil pressure is 0 at idle, Do Not Run engine at 3000 RPM.
Oil pressure should be 68.9 kPa (10 psi) at idle or 310 - 517 kPa (45 - 75 psi) at 3000 RPM.
If oil pressure is 0 at idle, shut off engine. Check for a clogged oil pick-up screen or a pressure relief valve stuck open.
Prof said:Your comments apply in double doses if the QC is red...![]()
