RP claims a HP increase,I'm using Mobil 1 ,just for the fact is,Im thinking there were a few $$ spent on testing this motor from Dodge and this is the oil they chose,must have been a good reason behind it somewhere??
On LPG there is no loss of horsepower.
With the right system there can be a increase of power because LPG cools the inlet.
You need to inject 20% more LPG then reguler fuel.
No, it's not recommended for 2 strokes. You might try some over your corn flakes though. Rotella has been known as a very good oil for many years. This is the full synthetic version of it and has all the approvals and recommendations and then some. More than Mobil 1.
I use Mobil 1 Turbo Diesel Truck.It has better /more engine protection in it than the Mobil 1 for regular engines.Check the ratings : SL is actually better than SM (being earlier and with more pollution causing agents)
There is a thread here that links to other threads that explain it all better than I can.Just do a search.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
