MSD Wires
nope...heres from the dodge service manual..
Failure to route the cables properly could cause the radio to reproduce ignition noise, cross ignition of the spark plugs or short circuit the cables to ground.
Release the fuel pressure, refer to the Fuel Pressure Release procedure in the Fuel Delivery section.
Disconnect the negative battery cable.
Remove the air cleaner assembly, refer to the Engine/Air Intake section for more information.
Remove the Intake Manifold, refer to the Engine/Manifolds/Intake Manifold for more information.
Use the following procedure when removing the high tension cable from the spark plug. Grasp the terminal as close as possible to the spark plug. Rotate the cover boot 1/2 turn slightly and pull straight up in a steady motion.Do not use pliers and do not pull the cable at an angle. Doing so will damage the insulation, cable terminal or the spark plug insulator. Wipe spark plug insulator clean before reinstalling cable.
Remove spark plug cable from coil first.
Always remove the spark plug cable by grasping the top of the spark plug insulator, turning the boot 1/2 turn and pulling straight up in a steady motion.
of course you can , just takes alittle patience, thats all , and of course a 12 inch small flat head,
i did both of ours without removing the intake, but patience is needed:D
Yeah, and you need to have Oompa Loompa hands.
By God you're a better man than I'll ever be if you can change them God Damn wires without removing the manifold. I'm friggin impressed Stinker, you may be my new idol...when I meet you, I'm gonna burn incense in your navel or something.
Tony is a GIT_ER_DONE kind of guy. He is very talented and quite an innovater.
That is very impressive!:rock: I pulled off my intake manifold to change my wires and I was cursing up a storm.
I'd hate to see what this man can do with a roll of duct tape and a coat hanger. The possibilities......
Viperpowered said:
You have to take the intake manifold off to change the plug wires on this engine!?!?!? WTF?
Yup, unless you have small hands and feet like Stinker :D
LOLOL TRUST ME!!
the easiest way is to take off the manifold, but lllllooooooooonnnnnggg time ago I was A line tech at achevy dealer and got paid by the job, so yeah I kinda learned to do things without doin much work!!LOL
but man what a pain it was!!!:D
They say that is an ol wives tale :dontknow: :D :p ;) ;)
