Unless he's got that beast de-tuned, I don't see it hooking up with DR's and caltracs.spray said:Yea my buddy called yesterday to borrow my drag radials to go run the twin turbo beast that ATF built for them. It should run some crazy times.:rock:
JTS VENOM PERFORMANCE said:tellem good luck spray:rock:
you ever get your tranny worked out?[/quot
Will do...
Have not got the tranny fixed yet, having to save up a little money since PATC ripped me then I am going to send it to HTS
spray said:didnt knoow if you got my last message to ya, but did you try removing the sct programmer and tunes and then try it?JTS VENOM PERFORMANCE said:tellem good luck spray:rock:
Will do...
JTS VENOM PERFORMANCE said:spray said:didnt knoow if you got my last message to ya, but did you try removing the sct programmer and tunes and then try it?
No I did not get that message but I will try it and give it a shot. Have you ever ran into that before?Thanks
spray said:JTS VENOM PERFORMANCE said:No I did not get that message but I will try it and give it a shot. Have you ever ran into that before?Thanks
actually a couple days after you called someone called me with the same situation as yours, dangit cant remember who it was tho![]()
but the next day they removed the sct and tunes(even tho its not supposed to affect the tranny) but it completly fixed his, so you might give it a try, def want hurt buddy![]()
JTS VENOM PERFORMANCE said:spray said:actually a couple days after you called someone called me with the same situation as yours, dangit cant remember who it was tho![]()
Gave it a shot but did not work.
