QuickSilver
Can you chime-in here "FSTJACK" and tell them what's going to happen to a set-up like this....... I think you've been down this alley.
Quick
Quick
Stinker said:he may under perfect conditions run out of gear,, yata yata, but again maybe not, have at it bro, and let us know.
The only real tire option I found was M and H drag radial, a slick with grooves, that is 390/40R17
rim 12 inch
tread 12.1 inch
sec. 14.8 inch
diameter 29.5 inch
or nitto drag radial P305/45-R18
Rim 9.5-11.5
sec/wheel 12.1 on 10
diameter 28.8
hope this helps
QUICKSILVER said:Can you chime-in here "FSTJACK" and tell them what's going to happen to a set-up like this....... I think you've been down this alley.
Quick
FSTJACK said:The short drag tire will help on the launch beacuse it is a soft compound "drag slick".
It is however too short to really hook as well as a 31"+ tire would work on a really agressive launch.
The contact patch is too short to put enough rubber on the ground. The difference in circumferance is 17", 83" vs 100" stock.
We knew that we could get a 17" rim on the 04 truck over 2.5 years ago but then as now tires are the problem. There is not a 17" drag radial or drag slick that is tall enough to work. The tire manufacturers tell me that they want a taller side wall on a wide drag tire.
This will work in a lightly modded 04 with a 4.10 gear not a 05 with 4.56's as all the 05's and up have.
A boosted or nitroused 04 will have to shift into 5th.
05's and 06's with 4.56"s will have to shift into 5th with any engine combination.
6000RPM in 04's with this tire will be 113MPH
6000RPM in 05's with 4.56 is only 101MPH
This tire/wheel will help but is not the real answer. The rear brakes need to be changed out to allow a 15" rim to be used.
With 15's your choices are very broad as to what tire you want to run.
There just are no good inexpensive ways to get traction with the Ram SRT-10.
Nowwhat said:and that is the complete and final answer......for now.....Patrick is talking to a couple of Brake companies...If we get 15 people to commit perhaps they will make a kit for us and then we can beat L's consistantly....![]()
Rice Eater said:Put me down for 1 of the 15!!!!! Can you grind the calipers enough to make 15's fit or only 16's? How are the tire choices for 16's?
I play it all by ear, but after looking at my dyno results shifting around 5600 is the way to go.Rice Eater said:TX viper! I was trying to focus on that but the shifts were coming up so fast! I may have been reving past that cause I was so excited...might explain it. What do y'all set your shift lights at?
Rice Eater said:NOWWHAT....the most fun I've ever had at the drag strip in any car! So much fun to just launch it off the line. I spun a couple of times...i will lower the pressure more next time for sure!
I don't think the tires were spinning on the 2nd or 3rd shifts. With the stockers they were for sure cause I could hear them chrip every shift even 4th! I think it was my shifts...probably being careful to not miss a gear...I'm sure I could shift faster....BOOMER....HELP!
Will Caltracs help me off the line and with the 1-2 shift w/ this setup? I am getting ready to order Boomers lowering kit and cal tracs if you all think they'd help me!
