My Truck in the American Iron Show
Prof
Wadsworth, IL
Engine Modifications:
Gen 4 main bearings used for 160 degree oiling, with extra feed hole for volume. Main and Rod Bearings have Teflon Coating for Durability.
Block: Cylinders honed with deck plates to size to fit .005†oversized Diamond pistons (Oliver Rods). Main bores in block have oil reservoirs machined into them. Block is line honed and deck’s were machined for clean up.
Crankshaft: Crankshaft is Nitride coated, ground and polished to size for proper clearance. Entire rotating assembly is balanced.
Pistons: Custom Diamond Forged Pistons-dished, for better combustion. Gold ceramic coating (gold) on decks of pistons with Moly coating (dark gray) on piston skirts. Floating piston pin for strength and light weight, rings have been file fit for proper ring gaps in bores.
Connecting Rods: Oliver Billet H-Beam Connecting Rods. 7/16 ARP Rod Bolts-bolts upgraded. 6.250†for better internal geometry.
Heads: Stainless exhaust valves, intake valves cleaned, ground and back cut for improved flow. New Beehive springs, titanium retainers, new keepers and seals. Competition valve job, ports cleaned and touched up, heads milled on deck and intake faces for cleanup.
Bearings: Gen 4 main bearings used for 160 degree oiling, with extra feed hole for volume. Main and rod bearings have Teflon Coating for durability.
Pushrods: Chrome Moly pushrods used for strength.
Engine was assembled on a flat surface instead of a rollover stand so that stresses would not be induced into the engine build. Camshaft Centerline was set at 121 degrees after TDC. Engine has Cometic Head Gaskets and ARP Head Studs. New Needle Bearing and Pilot Bearing in the back of the Crank and a new 1 piece Oil Control Valve in the oil pump.
Drive Train Modifications:
Centerforce clutch, Viper slave/master cylinder modification. X-Metal Gen IV shifter with Jedi lever. Moe’s Performance Drive Shaft Loop.
DTS “Stinker†rear-end with Strange 35 spline axles, Detroit locker/cryo ring gear (4:56 differential ratio). Cal Tracs. Wilwood racing rear rotors and calipers.
Exhaust Modifications:
Full Cat delete; MOPAR long tube headers (Jet Hot Coated), and Magnaflow muffler, crafted by Westech Automotive.
Boost Modification:
Roe Racing Twin Screw Top Mount Supercharger at 10 lbs boost
48 lb. per hour injectors
Roe Racing Water/methanol injection; Roe 5.6 ohm resistor mod it IAT sensor
Roe Polished Throttle Body
Tuned by “The Viper Whisperer†Sean Roe
Appearance Modifications:
Lowered by X-Metal
De-badged
Stock rims with PermaStar chrome finish by Goodrich
Fang shift knob by Avondale
JMB Hard Radiator tubes, Catch Can and Valve Covers (Candy Red)
X-metal alloy seat handles
Red and Silver Pinstripe by Jeff Williams Studios
Fang Badges front and rear
Etched Glass “Fang Supercharged†center sliding widow by Hot Rod Mike
Misc. Mods
172 degree thermostat
Dual Core Aluminum Performance Radiator Designed and Built by Sean Roe
Vector shift light
VEC III Piggyback to PCM tuning module covered by Eddie’s clear box
AB Ignition wires
Roe Racing Breathers
Fang Radiator Cap Cover by Stinker
Fang dip stick from Woody's Truck and
Woody's “RIP Woody†Memorial Radar Detector
Owner: Roy “Prof†Fouts, Wadsworth, IL
That sure is a pretty truck !! center of attention i"ll bet!! :rock:
very very nice Roy:rock::rock::rock:
how was the radiator install & ya been able to get any miles on it to see how it preforms????
I was next to a brand new Challenger Drag Pak, it got most of the attention.
Great show in a very kewl city, St. Charles, IL...spent the weekend and really enjoyed it!
The experimental radiator is wonderful...it runs about 7 or 8 degrees cooler on average, but the big difference is in recovery. I can see the rapid cooling effect of having a radator core that is double the oem size, and the 30% increase in fluid helps a lot too. It is beautiful to boot...those who know tig welding usually say: "that radiator is a work of art"...
was that by invite or ya signed up????
looks like an all Mopar Iron Show
indoor show would be sweet
It was a huge show. Indoor and outdoor, sponsored by the Chicago Land Mopar Club.
The indoor portion was an invitation situation...but we were not judged...the outdoor show had lots of cars (maybe 300, and yes mostly Mopar) but was open to all American iron to include motorcycles.
This was the first year at Pheasant Run Resort...I am sure it will continue there for a number of years...
Carl the tail lights make the truck! I still get comments on the Fang Viper that you put in them!
Thanks Robert! Those kind of comments is what it all about!
