Need help finding power steering pulley
hawaiisrt
Member
808state
Talofa uce's and fafine's
I was hoping someone could point me in the direction to find a power steering pulley for an 05 qc. I've searched the forum and the google thang but found none besides the mopar one. Is that the only option? $100+ for a plastic pulley My truck has a screeching sound when I start the it it's very faint but when you hit the gas it gets louder with the acceleration. I've removed the belt and it's still new (maybe 6months old) and all the other pulleys have no play in them and have no bad sounds when I spin them except for the power steering pulley. Thank you for any help and Aloha
I can help.
I don't believe that's your issue at all. Check balancer /damper bolt. Screeching is usually metal on metal of damper spinning on crank snout :(
Pulley is pressed on pump. You would likely need a pump and not pulley boss. Let's diagnosed it correctly then I can help with parts. :beer: with
Yeah... What he said. If it definitely screeching from power steering pump pulley then u may be on your way to having to get a new pump.
Still say check balancer/damper and idler and tensioner pulleys once more. Spin them with your fingertip pretty fast
I'm having the same sound with mine. got new idler and tensioner pulleys have to install this weekend. I'm having a tough time steering when the engine is at idle and is warm. i have give a slight rev to gain any assist in steering. thats why I'm thinking its the pump. but just replacing other possibilities while its down. might as well do new lines as well. also read to check the crank pulley bolt if its an 04 some of them like to come loose. any update on yours?
Exact same issue here, I lose power steering at idle (esp when cold) and low RPM through turns, did you get yours figured out?
