Marc T
Check engine light is on, code P0310, can anyone help???:dontknow:
Thanks
Thanks
# 10 miss fire.Marc T said:Check engine light is on, code P0310, can anyone help???:dontknow:
Thanks
Marc T said:I was cleaning it and I may have hit the injector wire!! Are they that sensitive??:dontknow:![]()
Which is the # 10 cylinder??
\\RedSrt007 said:Passenger-side rear'est' cylinder...(closest to firewall)
-Red
mmmmtorque said:Cylinder #10 misfire...
May be a random anomaly....after you cleared it, did it come back ? If so, would check the injector and plug.
FlyingLow said:How does it run? That is the code I threw for the number 3 (303). Pulled the plug and it lost the gap. But the truck was running very rough so I knew something was not right. If your truck is still running smooth then just reset it and see how it goes. Could have misfired once.
Marc T said:How do I clear it???
