Pulled the heads today and its a collapsed lifter
I have a lifter problem, mines coming back apart.
What lifters are u using
Im using the gen 2 lifters as well.
No I didnt have any other symptoms. I did a pull at wot I heard a ticking sound. Everything seemed normal so I thought I blew a hole in my magnablow
But I didnt find any metal shavings in mine at all
Since yours is apart, its stuck in my mind I put this thing in sideways. Can you or do that have to line up.
I think the roller is sideways on the cam
You can put the lifter in any way. But im pretty sure the locker only allows for it to go in the proper way
Ordered all the parts that I needed today. The lifter was 18 bucks. And I was able to only order 1 head and 1 header gasket. Popular belief is that you have order them as a pair but I guess not. Most expensive part is gonna be the head bolts. Cheapest iv been able to find is about 375 for arp head bolts
Im just gonna get arp. Some day itll be boosted
Get the studs, and your will need a bottoming tap to get the studs in w/o forcing them. If the motor is in the truck test fit all the studs, then take them out put the head on first then put the studs in. I thought the studs were a great upgrade over the bolts. 450 from summit racing, and yes I called arp the studs are reusable, they just need to be measured.
...and I cut the siznit out of my hand on the head gasket.
