Jack, are you still using the slicks that have traveled from NC to IL to TX and then to you?
http://www.vtcoa.com/forums/showthread.php?t=44772Prof said:Jack, are you still using the slicks that have traveled from NC to IL to TX and then to you?
No Roy, I finally replaced them with some new ones. They still had good depth but the compound was getting hard.Prof said:Jack, are you still using the slicks that have traveled from NC to IL to TX and then to you?
I shoulda thought about that myself!!Prof said:They got hard????
Hell I should have kept them...I need things that get hard...bad.
going to a real track jack?FATJACK said:Going to a great 1/4 mile track in about 30 days will certainly give it a try.
60' times above about 1.90Troy's QC SRT said:How do you know when the DR's need to be replaced?
FATJACK said:60' times above about 1.90
You'll break the 2.0 mark consistantly with the DR's. The DR's wear wear bars, just like regular tires. Once the tread is even with the wear bars, it's time to change. Mine are just above the wear bars. I got one more night at the track with mine. But, at the point that they're at now, the dont hook very well with the new torque converter.Troy's QC SRT said:How can you say that...What if I jsut suck and I can't get better than that! I need caltracs as I have bad axle hoop but I know I want to hit the track soon to try out the DR's and I didn't know they could really go bad besides the obvious dry rotting.... I mean without caltracs I might not get over a 2.0 anyway....
SANTEEN said:You'll break the 2.0 mark consistantly with the DR's. The DR's wear wear bars, just like regular tires. Once the tread is even with the wear bars, it's time to change. Mine are just above the wear bars. I got one more night at the track with mine. But, at the point that they're at now, the dont hook very well with the new torque converter.
