New billet aluminum Forced induction Overdrive pulleys Now Available!
JTS VENOM SERIES
Billet Aluminum overdrive Pulleys
$299.95
A totally new design over our old pulleys, these pulleys when used alone will develop approximatly 2psi or more lbs of boost on a Paxton or Roe supercharged SRT10, with other years and models being currently tested. Fit, finish, and durability was a priority when we designed the new pulley to provide years of great looking service. The larger crank pulley is designed to add hp and boost without belt slippage issues such as when only the smaller upper head unit pulley is used. The larger pulley provides more surface contact area for the belt resulting in less of a chance of belt slippage issues, resulting in more boost and hp at higher rpm levels. Although when used in conjunction with a smaller head unit pulley even higher boost and hp levels are obtainable and you are less likely to have belt slippage problems.
These overdrive pullies are designed to be used with the oem dampner or the ATI dampner. When you purchase your new Venom Series overdrive pulley, you will recieve a pulley and an adapter. Use the adapter for oem dampner applications and without for ATI dampner applications. The adapter is provided at no additional charge, and is designed to centralize itself on the pulley to fit perfectly.
The pulley is cut from T6061 billet aluminum and polished for great looks, corrosion resistance, and years of great looking service. Great attention to detail was given to the corners and design of the pulley to give eye catching looks at the track or at shows, along with small details designed in for longevity.
The Adapter is cut from T7075 billet aluminum known for being one of the highest strength aluminum alloys, used to give the customer years of great service.
So if you are running a forced induction SRT10 and are looking for a few more lbs of boost, or if you just want to add some hp without the worries of belt slippage, this pulley is for you, great looks and a heavy duty design, our pulley should give you years of great looking service.
Look for more JTS VENOM SERIES billet pulleys comming soon
thanks
"Stinker"
JTS VENOM SERIES
$299.95
thanks
"Stinker"
