new guy here got some ?s
Status
Not open for further replies.
Welcome to the family,
You will find a wealth of information on this forum for your ride.The bottom line is power to weight...The Lightning weighs a lot less than your 10,so shedding a few pounds and building to the power level you need is in order.Learning how to properly launch the 10 is also a big part in lower e.t.s.If you want to go 11s,shoot for around a 7.5 power to weight ratio.If the lightning guys give you a hard time,Just tell them you will run them from a 120 m.p.h. roll!!!:D That will shut them up,And then add that your truck will out brake,Out handle and is just plain cooler than any Lightning!!:burnout:
As a last resort,Tell them to put another 700 lb.s in the bed so the weight will be close and have at it!!!
All you need to beat the lightenings is cubic dollars.
Welcome.
If the slowest one runs 11.60, then your going to need more then simple mods ;) Get a paxton, meth, headers, and inlet tube, and with a good driver you'll be real close.
Replace the good driver with a set of DR's and you'll be closer.:rock: :D
Status
