After a couple weeks of tinkering, I finally got around to snapping some photos. Flat black stripes, Magnaflow catback, K&N intake, Groundforce lowering kit 1/2, KMC backseat wheels with 4" lip, 1/4" wheel spacers, tinted windows, tonneau cover, body-color handles/mirrors were all on the truck when I bought it. I started out with a complete fluid change (Mobil1 15W-50, ATF in the tranny, 75W-90 differential), new oil and power steering lines (stock ps line was leaking above the pump, turns out), stainless brake lines, and polyurethane sway bar bushings from Stinker (excellent customer service, by the way--I called with a question in the middle of the ps line install and got his voicemail, and within 15 minutes Tony had called back!). Then, a little paint on the interior trim pieces:
Installed a B&M short-throw and a JVC Arsenal (headunit and amps)/Kicker sound system. Component speakers in the doors with the tweeters mounted in the sail panels, amps and 12" CVR subwoofer on the back wall of the cab, coaxials in the stock rear-fill location:
Also, I pulled the whole interior out and laid vibration-damping mat (Second Skin Damplifier), closed-cell acoustic foam, and mass-loaded vinyl (1 lb/sq ft--used about 60 sq ft. But I don't weigh much, so I figure the truck can take the extra weight). No annoying drone now!
On the outside, I rattle-canned the calipers Snakeskin Green to match my new JMB emblems (will probably powdercoat them in the future, when I feel like spending more):
I also put in a black honeycomb grill, black headlights with clear side reflectors, HID heads and fogs (6000K), and LED lighting everywhere else. The parking lights are especially cool--they shine white until the turn signal is applied, then they flash amber.
The whole thing:
Whadya think?
