:rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock: :rock:tinygiants said:I am thinking of trying to make my own Nitrous Bracket. I was planning to do it in aluminum like I did for the throttle body spacer.
I may try that after I get my truck back.labontecsi said:How's about some wire looms for MSD's?
I spoke with fstjack about the wire looms. Seems someone already makes them. He also warned me about using metal for the loom material. Seems that if there is a weak spot in the protective sheath, it will arc out. I may have to look into making them out of phenolic instead.labontecsi said:How's about some wire looms for MSD's?
tinygiants said:I spoke with fstjack about the wire looms. Seems someone already makes them. He also warned me about using metal for the loom material. Seems that if there is a weak spot in the protective sheath, it will arc out. I may have to look into making them out of phenolic instead.
I am going to line the bracket with rubber liner.blackviper said:That looks sharp Dale. How do you plan on keeping the bottles in place?
Sure sounds good. Can you give me the dimensions of the insert? I will do a quick CAD based on those dimensions and shoot it over to you.Ram From Hell said:Nah. Just oversize the slots in the looms and use a high-temp dielectric insert around the wires. I have a good design in mind. Let me know if you want to co-develop some.![]()
tinygiants said:Sure sounds good. Can you give me the dimensions of the insert? I will do a quick CAD based on those dimensions and shoot it over to you.
I guess we have a project on our hands thenRam From Hell said:Gotta find/make the inserts first.![]()
tinygiants said:Making Progress
Now you tell me!kyle's srt10 said:Wish I would have known you were making these this way Dale. Could have saved you some time and cut them on my plasma table and been perfect![]()
They still look awesome though:rock:
tinygiants said:Now you tell me!![]()
What kind of a edge does the Plasma Table Leave?
If it turns out nice, I may have a few more to make for some folks.
Thank you for the offer, as I may seek to take you up on it in the future.
1/2" 6051 Aluminumkyle's srt10 said:How thick is the material?:dontknow:
