nitrous explosion
AARHEMI
WICKLIFFE OHIO
well my intake and scoop are trashed and had a small fire went to get my bottle filled at the place my brother work,s and the a&& hole who filled it did it wrong and all i got was gas instead of liquid so when i took it for a test run it went bang big time lifted the scoop and blow apart the intake the owner was pissed that the guy did that but there covering the damage stuff and gave me a free spare bottle with a free refill after i paint it
The owner was pissed because you had him in a position where he had to make it right on his nickle. Geeze dude, you didn't get hurt right?
Sorry to hear about the damage,at least they are covering the repairs.
no i,m ok just pissed the boss even called his buddy at zex who is the v.p. and they told him the guy was at fault because he didn,t fill it right
Whew! You really dodged a major catastrophe!!! Glad to hear (besides the damage) everything is OK. Sad to see your hard work and time be wasted thou:mad:
Yikes, that is scary...........thats good of the owner to fix the damage. :congrats:
They : should monitor that better,don't know if the guy is green or simply made a mistake, cause he was thinkin about the next project :dontknow:
You didn't notice that the bottle was 10lbs to light, and neither did he? How did he measure the weight it to fill it?
dang john i'm sorry to hear that man at least it didnt f up the motor time to take full advantage of this and get some new mods
That sounds strange to me.
If the bottle was only gas you would have been way to rich when using the NOS. That should make the engine stumble from too much fuel. (The same way it stumbles when the bottles empty)
A NOS back fire needs to be LEAN meaning Not enough fuel.
You might want to check the fuel solenoid make sure it is working.
Just my $.02
500H V10
Just my $.02
500H V10
Agreed....................
BTW when you are using NOS please use a spark plug that is 2 steps colder. Hot lapping using NOS will also cause a backfire.
Just my $.02
500H V10
It'll backfire with to much fuel. I made the mistake of leaving my system armed once and sprayed by accident at wot. Kaboom, blew the CAI off.
i,m running the colder plug,s and taking 4deg. of timing out
Just my $.02
500H V10
Um... a nitrous back fire is cause by fuel puddling in the intake, once there is enough fuel it ignites, if your lucky it's while no nitrous in going through your intake(like this guy) and it just blows your air box up. If your unlucky and it back fires as your spraying the added no2 and fuel mix in your intake blows the top of the motor off. (like that gto that was posted a while back).
that must have been what happen i,m lucky i have hit the nitrous 2 times today with no trouble
