Snake_Charmer
I know there is some older threads out there about this, but i wanna get some newer updates from people running a nitrous/propane setup. Any engine problems on 100-150 shot stock guts?
I am buying a kit. if its 100% safer and added tq to run the propane then y not. regardless. are you on stock internals if so how often are you spraying?
e85 and nitrous good to go dont bother with the propane?
Why do you feel the need for the extra octane with a 150 shot? Just put a standard 150 shot on it and it'll be just fine.
No, not 100% safer bro. The cylinders still see high pressures regardless of fueling used. Propane can be less expensive and achieve the same results as race gas, having less resistance to detonation.
More octane is always better but that can come from e85, or simply higher octane conventional fuels.
The biggest reason why you do not see it is there really is not much of an advantage over easier to tune fuels. Have you any idea how to read a plug when using propane as the enrichment fuel?
It is certainly a cool idea and a feasible one, but it is not as simple as you are wanting it to be.
Also NX and NOS will be zero help on this. I would not start this unless you are comfortable doing nitrous tuning and reading plugs.
is your SN on LS1tech w3s1c0a5t?
I think it is something that is another why not scenario. or a peace of mind.
Why not, added cost and complexity for absolutely no reason. It's been proven time and time again that a 150 shot is nothing on these engines so why try to reinvent the wheel, just stick with what is proven to work. If you planned to run a bigger shot(200+) then I'd say go for it, personally I'm just going to stick with race gas when I want to spray and want to add a nano pusher kit to keep my bottle pressure up thru out a pass. I've noticed a pressure drop of about 200psi on some passes.
