mopar_mudder said:
OK do a burn out from the start line 1/2 way down the track, whats that got to do with any thing :dontknow:
First off, I have been kind of baiting you. Not your fault. Just a shitty week at work.
Sorry for being an ass.
Anyway, back to the subject.
This is from your first post on this subject.
I don't normally disagree with my elders, buuutttt. Well I got so say you are a little off on that. A locked or working posi rear ends is what generally causes these problems. When both tires are locked and spinning they pretty much have a mind of their own are are going to try and pass the rear end any way they can, this is even worse when coming trough a corner. If you have an open rear you are going to just spin one tire and the other acts like an anchor holding the rear end from sliding side to side.
Just because both tires are spinning does not automatically lead to loss of control or fishtailing. If this was true the TF and FC boys would not be able to do burnouts.
With a spring/clutch type posi unit like we have it is always trying to send the power to the wheel with the most traction. Hence the fishtailings as it's not equal power being sent to both wheels. Make sense so far?
Okay, now for the locker unit. As soon as it senses an slip under power it locks up. No trying to send power to the wheel with traction. It's sending it to both wheels the same. So in essense the locker style posi unit is like a spool when it's engaged.
This is why Roy is saying what he is saying. The rearend is no longer searching for the wheel with traction. It's like a spool, so he is going nice and straight.
Now other outside influences can affect this. Crown of the road, oil or any other substance that can cause one wheel to have more traction than the other. In that case it will indeed wage the tail. Then you have engine torque that can also influnce it if you let it.
Anyway, I think what I was trying to do was lead you down a path such that you would think about this and maybe arrive at the answer yourself.
Once again, sorry if I came across as an ass. Was not my real intention.
