i can make it that way for you
What tires are you currently running, auto or stick & what HP are you at??
Ladder bars are better than traction bars.
Glacier Diesel Power - Product List
Or make a set yourself.
He is running "M&H Racemaster DOT Drag Radials", it's an automatic, and the horsepower isn't nearly as impressive as the torque.
Pro comps look the same for $600 and they will bolt on our diff too!!!
Pro comps are traction bars, not ladder bars with the pivoting front mount.
But when I posted that I didn't realize he had the Caltracs.
The difference between a ladder bar and traction bar is that a traction bar is mainly to prevent axle movement forwards and backwards along with some twisting.
Ladder bars have a pivoting front mount which allows the axle full range of movement front and back but prevents axle wrap.
You'll probably be able to find a much better explanation than mine on some of the diesel sites.
Look at the difference between these and the glacier bars I posted earlier.
http://www.procompusa.com/prodDetail.aspx?partNo=EXP72501B&catID=1&subCat=101&ptID=3177&plID=1830
If 700 hp ain't impressive, you might be a fighter jet pilot.He is running "M&H Racemaster DOT Drag Radials", it's an automatic, and the horsepower isn't nearly as impressive as the torque.
