o2 wire extenders
Rickspeed
North Carolina
I bought a used set of Mopar Long Tube Headers, and did not get the extenders for the Front o2 sensors, anyone know where i can buy some? I need 2 for the front o2 sensors. I have elec sims in the rear 2.
hashash said:
try Stinker or Dragon
I pm'ed them both, waiting to hear back, i guess on the 05 ram you need them for the front o2 sensors, you said you used them for the rear ones, right?
tried to contact the performance hotline but they were no help. i will keep looking.
yeah I called the mopar hotline too... not available seperately. AEM is the manufacturer of these headers but I've tried to get parts for other stuff they make for mopar and they wont sell it. It looks as if you must make your own.
it shouldnt be to hard only like three wires. just make sure to use the heat shrink connectors.
Thanks everyone, bought some new Bosch oem ones tonight at autozone, gunna cut splice and make some longer connectors tomorrow.
good luck
thinking about it , i forgot which ones need extending . You have to check first .do not take my word for it.
Has anyone tried Roe Racing?
He put on my Mopar Long Tube Headers and probably would have the extenders.
looks like I need 'em too!
where did you finally get? how do they look like?
I'll probably cut the stock cables and solder an extension...
I went to autozone, and bought 2 new front ones for under $60, cut the wires off the old ones and soildered them to new ones which doubled the lenth of each, which was more than enough, and still had oem harness that plugged right in. Hope that helps.
carp you mean they wont fit the stock one's on the mopar long tubes ? dammit
ok - i guess i have a problem, bc i made the extenders on the O2's i got the driver side in but... the pass side i cant reach the connector my headers are installed and i really dont want to remove them to put in the sensor :(
any ideas ????
Not sure about the '05, but on my '04 I have both rear sensors strapped to the frame, with both bungs capped and mine has never had a code. Worth a try...
any ideas ????
Without seeing it, sorry to say, break out the tools...???:dontknow:
